RE: Capiche 50
Saitos are AAC (well most are). They are also ringed. With a 4 stroke the moving bits dont get the lube that two strokes do as the fuel goes in and out the top, rather than through the crank case. Half the run in process is to get oil to all the bits needing it before you start to stress it.
