RE: ESM 57' extra
Went for a diferent way of fitting the wing belly pan..In sted of epoxying it to the wing ive made it removable by putting 2 paddle pop sticks on the front of the BP and slotted the fuse for them to fit into when the wing has been mounted.. On the wing mount ive added some triangle stock for the rear of the BP to be screwed to once it has been pushed in to the slots at the front..
Also an old 46fx being mocked up to get the motor mount fitted as it has the same size mounts as the 50SX that will be going into it.
