RE: Generator
Hi Tony,
Thanks for the update on the electric Partner. I looked on the Hacker website and could not find the new 90 amp controller. What is the part number they sent you? Am I correct in saying if you run the 22x12 prop you will pull 65 amps and still be safe using the master 77 3p opto controller with no overheating problems. Have you now gone back to just running the 22x12 prop? Will running the 24x12 prop with the C50 14XL motor be ok as long as you are using the new 90 amp controller? With the new 10s3p pack, are they two TP5700-5S3P packs and are you using two chargers when recharging them between flights? Thank you for your time in answering my questions as I am trying to gather info on what is currently working for electric pattern.
Scott
