RE: THE CHALLENGE TO CREATE THE U CAN DO 46 OR 60!
Specs for the U Can Do46-wingspan 56.75 in- length 58.5- wing area 904 in sq- weight range 5lbs -5lbs 10 oz- engine range 32 to 50 2S, 52 to 70 4s-cg at 0-no dihedral- 0degrees wing incidence-no sweep back on te or le.
