Go Back  RCU Forums > RC Airplanes > RC Flight Simulator Software
 THE CHALLENGE TO CREATE THE U CAN DO 46 OR 60! >
RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Old 04-27-2004 | 05:12 PM
Default THE CHALLENGE TO CREATE THE U CAN DO 46 OR 60!
I pose this challenge to all who can! Does any one on this website have a U CAN DO 3D for the real flight G2. I have add on #3. I will be eventually creating a UCD color scheme. But if any one that reads this has already or has the abilities to create one please do and send it to the swap page.What I am looking for is the aircraft version not the color scheme. Any one that creates one thank you in advance!!!!!!!!!!!!!!!!!!!!
Old 04-28-2004 | 08:49 PM
Default RE: THE CHALLENGE TO CREATE THE U CAN DO 46 OR 60!
Fly Boy 1:
The main challenge here is picking a stock G2 plane that is close in style to the U-Can-Do. After that you just take the measurements off the real plane and edit the sim model. I did this with the GP Dazzler, making it fly very close to my real Sig Somethin Extra.
I'm not sure which G2 plane I'd start with for the U-Can-Do. Perhaps the Tracer (patten plane) with a different airfoil? Maybe the Dazzler. G2 and the add-ons do not currently have any real "3D funfly" planes. You hae to pick something close like the Dazzler and go from there.
Carl
p.s. w/o the U-Can-Do measurements I can not do this.
Old 05-02-2004 | 09:30 AM
Specs for the U Can Do46-wingspan 56.75 in- length 58.5- wing area 904 in sq- weight range 5lbs -5lbs 10 oz- engine range 32 to 50 2S, 52 to 70 4s-cg at 0-no dihedral- 0degrees wing incidence-no sweep back on te or le.
Old 05-02-2004 | 04:34 PM
Just got done with the color scheme for the ucd 46!I am going to post it to the g2 swap page!!!!!!!!!!!!!!!!
