RCU Forums - View Single Post - How does MVVS rate
Thread
How does MVVS rate
05-02-2004 | 12:40 PM
65
TRITINY
Apr 2004
27
PuchongNOT APPLICABLE, MALAYSIA
RE: How does MVVS rate
If you run an OS too lean or under prop it you'd loose the crome on the cylinder which will cost half the cost of the engine to replace.If you do the same with MVVS you'd loose the idle needle would'nt cost much
Reply
Like
TRITINY
View Public Profile
Send a private message to TRITINY
Find More Posts by TRITINY
View iTrader Profile
