RCU Forums - View Single Post - post some pictures of those 3D models!!!
Old 05-02-2004 | 03:48 PM
  #155
Sprink's Avatar
Sprink
Default RE: post some pictures of those 3D models!!!
Some photos of my new Seduction Wildstyle. Had its first flight today, only one but enough to tell me that this is a good fun plane. couldn't have more as two of the four engine mounting bolts had shaken themselves loose [:@].
Power is a Saito 56, with an APC 13x4W providing plenty of thrust.
Standard Futaba rx and 1000mah nimh battery, 4 hitec 225s and a SD200 for throttle.
Dry weight is 1700 grams, 3 3/4 lb
First flight and i got some nice parachutes and elevators out of it, but harriers are a bit unstable at the moment. Knife edge is very easy with no roll coupling, but a tiny bit of pitching to canopy. Though this is with out the cowl which could make a difference. CoG needs to go further back as well, as I needed a lot of down for inverted.
Just so you know, I did not bother with the wing tips, so left them flat, and left the cowl clear as I thought it looked cool like that.[8D]
ID:	128414   Click image for larger version
ID:	128415   Click image for larger version
