RCU Forums - View Single Post - Will it run hot?
Old 05-03-2004 | 04:44 PM
Bax
Default RE: Will it run hot?
Overheating is caused by poor airflow through the engine's fins. In a pusher installation, you have to make sure that air gets through the fins. You may have to make a shroud around the engine that makes sure that air goes through the fins. When the airboat's moving, a scoop should help gather air to go through the cylinder fins.
