RCU Forums - View Single Post - Beginner Lesson Learned! Your right, you DO need lessons!!!
Old 05-03-2004 | 08:35 PM
Flyin_High
Default Beginner Lesson Learned! Your right, you DO need lessons!!!
Well I finished building a Kadet Senior a LONG time ago, and I was fed up waiting for warmer weather, because no one would show up to the club to give me lessons. (you know where this is going)
So I loaded my plane up, went to the local high school, and started her up, and I took off. I pull up (a little to much I learn now!!!) and the plane went in a vertical. The little bit of wind took it and rolled it backwards sending it in another vertical. (Just the opposite direction. Towards the ground). And before I knew it, it nose planted in the ground.
So I have come to the conclusion, when you guys say NEVER to fly without lessons, your right.
Just had to prove that for myself.
Any rebuilding suggestions would be greatly appreciated
ID:	128929   Click image for larger version
ID:	128930   Click image for larger version
ID:	128931   Click image for larger version
