RCU Forums - View Single Post - When do you install the motor?
Old 05-04-2004 | 10:37 PM
FHHuber
Banned
Default RE: When do you install the motor?
when spltting the costs up... recommend gettig the RADIO first.
You can build some "entertaining" things that fly using anything from old refrigerator boxes to coroplast signboard. You can get a $5 foam glider from Wal-Mart or other discount toy places (sometimes theya re in the grocery store too...) and add controls for a decent 2 channel glider.
Then get the engine... and go with the "SPAD" type trainer. this is a model made of coroplast signboard and PVC downspout. (you even cut the control horns from the downspout material) Bicycle spokes from a scrapped wheel or coathangers to get wire for pushrods. You can even cut the wheels from coro signboard... so what if you have to replace the wheels every 4 or 5 flights? They're virtually free. These tend to be a bit ugly... but you can make some beautiful coroplast models with research into the needed techniques.
Coroplast can be free... from the local "quickee-mart" old advertising signs fly well.
www.spadtothebone.com
THEN get the more fragile wood construction aircraft. The wood planes do tend to be lighter than the SPADs and thus fly a bit better. (but Ihave made some very light, high performance, SPAD's...)
The purpose of this method... get in the air faster on a budget without buying JUNK. If you have the money to buy the ARF package deal... that is probably the best way to start now.
