RCU Forums - View Single Post - DA 50, Is this normal?
Old 05-05-2004 | 12:54 AM
Antique's Avatar
Antique
Default RE: DA 50, Is this normal?
Engines require clearance between the rotating parts...The noise you hear could be coming from 3 different places, side clearance between the rings and piston groove, up and down clearance in the wrist pin and its roller bearing, and the same thing on the big end of the con rod...You can call Dave tomorrow to confirm this.....
