RCU Forums - View Single Post - When do you install the motor?
Old 05-05-2004 | 08:05 AM
Fastsky's Avatar
Fastsky
Default RE: When do you install the motor?
The servos, fuel tank, servos, and then the engine are usually the last things to go on the plane. Then the prop, spinner, receiver, and battery pack need to be installed so you can check the cg. Make sure the fuel tank is empty.
