RE: DA 50, Is this normal?
If you run the engine lean-on a pipe (easy to do if you don't have experience there)
you can wreck it in a single run.
Check with Dave Johnson of best setup - Do not overprop it .
Don't go by size of prop -go by how the engine sounds and responds.
