RCU Forums - View Single Post - Freestyle Rush
Old 05-06-2004 | 04:17 AM
Spacey's Avatar
Spacey
Default RE: Freestyle Rush
Buzz
Mine has all the servos in the front. I've put pull pull systems on both elevators to remove all the slack and the plane is laterally balanced. You can't maybe give me your exact measurement of your CG from the LE at the root of the wing please? From reading all the funtana problems and the guys saying that moving the CG back helps? I'm a little confused with this concept. Mine was also VERY unpleasant to fly. The whole white knuckle thing you know, you never knew when it was going to flip over a couple of times
