Ok some more pics. Engine is fitted up and mounted 90' insted of the 30' from vertical as stated in the manual..It was that way so a bigger std pipe would fit in the cowl or atleast down the centre..
Aileron servos are screwed to the balsa bocks that are epoxied to the wing cover.A little bit of wood had to come off the inside of the wing for the servo not to rub against, but other than that its your normal wing fit out.
Here is the ESM extra up against a Blackhorse extra. Sizes are pretty much the same but the BH has a higher rudder, but the ESM makes up for that in area with alot more length to it.Stabs are the same size but like the rudder the elevators offer more area.
In the middle of the radio fit out next and to fit the push rods to there homes.Anyway enjoy, hope to have it flying this sunday as i have nothing to fly otherwise..
