RE: 46cc Poulan Needle Settings??
The main thing you want is a good idle, and good transition to full throttle. If it starts up, and will run at a decent idle, you should be close. Needle settings are not a one size fits all. You need a tach to accurately set the top end. Just don't go for max rpm. Always set the hi spd. needle a little rich.
Z
