RE: Futaba 6EXA Mixing
Andrew,
The functions are detailed clearly in the instruction manual...beyond that its just not possible for Futaba to lay out everything in an ad, for example, every detail of every feature? Just can't do it.
Please try to re-explain what you're trying to do, as ch 1 and 2 wouldnt be flaperons. I assume you mean 1 and 6? and activated flaperons? What exactly is happening, what's the problem, etc? 60% travel is a lot of travel for flaps for a normal model.
You do need to remember this is a budget price tagged, "less than the 6X" entry level computerized radio. It is meant to handle very simple, basic setups, and that's all. As you say, if you want to do more complex special needs, such as 3D airplanes, you need to look at a 7C or similar.
AMC
