How do you stop the engine?
If you use the throttle trim for idle adjustment make sure it closes your carburetor all the way when down. Set the idle with the trim up so that when you pull the trim back it shuts off the engine. After shut down pull the fuel line off the carburetor and run the engine dry. Be careful with your thumbs while in fllight so that you don't accidentally close the carb.
