RCU Forums - View Single Post - Pull-Pull Setup Problem on Extra Special
Old 05-11-2004 | 01:17 PM
ptgarcia's Avatar
ptgarcia
My Feedback: (36)
Default RE: Pull-Pull Setup Problem on Extra Special
And make the distance between the wires at the servo and at the rudder control rod the same. In your case, since the servo arm is probably fixed at 3", make the distance between the wires at the rudder 3" also. This will eliminate the slack problem. Good luck!
