Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - 3D & Aerobatic
 Pull-Pull Setup Problem on Extra Special >
Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Old 05-10-2004 | 08:37 PM
murrat's Avatar
Default Pull-Pull Setup Problem on Extra Special
I am having a Pull-Pull setup problem.
My setup is as follows:
On Servo I have a 3 inch Full Arm. On Rudder I have a 3 1/2 inch threaded Rod. With dubro gear drilled out right at the hinge line. (Same gear you sell in your hardware kit Tom)
Wire is crossed inside the fuse.
Problem 1) The wire is cutting into the fuse at the back of the slot holes. I cut the slots back as far as I dare, but the wire is still rubbing on the back of the slot. Should I not be crossing the wire in the fuse to resolve this.
Problem 2) I am getting slack in the lines when I move the rudder. Appears to be happening more on one side. Perhaps this may clear up if I resolve problem 1.
Any suggestions?
Old 05-10-2004 | 09:48 PM
rctom's Avatar
Default RE: Pull-Pull Setup Problem on Extra Special
Uncross the wires.
TF
Old 05-11-2004 | 01:17 PM
ptgarcia's Avatar
My Feedback: (36)
And make the distance between the wires at the servo and at the rudder control rod the same. In your case, since the servo arm is probably fixed at 3", make the distance between the wires at the rudder 3" also. This will eliminate the slack problem. Good luck!
Old 05-12-2004 | 01:50 AM
murrat's Avatar
Thanks, I used both suggestions. Made a big difference.
Todd
