RCU Forums - View Single Post - Pusher/Puller
Old 05-11-2004 | 02:50 PM
Villa's Avatar
Villa
Default Pusher/Puller
Is there any information on flying a pusher puller configuration with regards to matching the props when using two identical engines, say .28 size or larger? It seems to me that the pusher mounted behind the wing needs to have a prop with a higher pitch than the front one doing the pulling. The pusher is seeing higher velocity air.
