Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
Pusher/Puller
Old 06-30-2004 | 11:57 AM
Default RE: Pusher/Puller
Hello Rudy,
Christaneagle is Tim, just kidding about the four strokes.
Old 08-02-2004 | 02:58 PM
Villa's Avatar
Here is the final version of my Puller/Pusher. Does a knife edge all day long; wild snap rolls; Has done lomcevaks but I don't enjoy flying with the CG that far back. Hammer head stalls are beautiful.
Old 01-23-2007 | 07:12 PM
Villa's Avatar
After solving the major problems I paid attention to some of the minor problems on my Pusher/Puller. It would pitch down at full throttle and pitch up at low throttle. I think that is what it was doing. It has been a year or so. At any rate, I traced this to the rear engine being a little higher than the front engine. A pitch down moment was being created. I put the engines in line, but the rear engine had to move back. This meant the front engine had to move forward to hold the CG. The end result is OK. Flies great. One of these days I will change the fuselage from 3/4 inch channel to 1 inch square tubing. There is way too much flex in the front wheel assembly. I carry a little nose weight in the form of lead, so a heavier fuselage may not add to the total weight. I also changed the main gear so that it was stronger with little increase in weight, and so that toe-in stayed positive with rear. This greatly improved ground handling. Here are two new photos showing some of the changes.
Old 01-23-2007 | 07:15 PM
Villa's Avatar
Photos did not go thru. Here is another try.
ID:	605197   Click image for larger version
Old 01-23-2007 | 08:57 PM
Villa's Avatar
To the Moderator. Can you please move this subject to the SPAD forum? It is multi engine, but it is a SPAD first. Thanks
