Thunder Tiger Pro 46 - Dead stick
Either you are too lean. eventhough you held the plane vertically to check it. Peak the engine with the needle and then back down on the rich side 2-400 rpm. Then try the holding up and also the transition from idle to high speed.
Or your clunk has flipped backwards if you had bumped it from the nose previously.
Good luck,
Jim
