RCU Forums - View Single Post - flywheel/collet problem....
Old 05-12-2004 | 03:37 PM
rc10gt4master's Avatar
rc10gt4master
Default RE: flywheel/collet problem....
is your shaft too long? what you are describing sound like you put the clutch nut on but you cant tighten it enough to hold the flywheel? shorten the shaft if thast the problem just take a dremel and cut away a few threads
