RE: futaba servo plugs
You might just have to buy servo extensions and cut them to get the female ends. What would you need female ends for? Other then switches or extensions...unless your making your own extension. If that's the case, just buy the shortest extension, splice into it add wire, solder it tight, and your done.... don't know though.......just throwing thoughts out.
