RCU Forums - View Single Post - Aeropoxy ?
Thread: Aeropoxy ?
Old 05-14-2004 | 04:44 PM
Shaun Evans's Avatar
Shaun Evans
Default RE: Aeropoxy ?
I think what happens sometimes is that the tubes are not exactly filled to the same level. When you go to squeeze it, the air bubble is bigger on one side. Consequently, the first little bit is unmixed resin, and it simply never dries. I like to use the clear mix tubes you can get from Tri-City paints so that I can see it mix up as it goes in. Hope this helps.
