ORIGINAL: NOVAflier
Pre-load the springs, I don't follow you (huh, and I'm an Engineer)...
It just means to stretch the springs out so they have some tension on both of them. This tension will give you the stiffness you need to steer. With more pre-load, you get more stiffness in the tail wheel. Not too much though, or the servo takes a beating.
