I saw in the marketplace that U R selling this plane.. DON'T DO IT!!!!! This is the best flying plane I have ever had!! It will fly well with the CG aft of recomended.. I have all three servos mounted in the tail, with a heavier Moki 210 up front.. I'm not sure how many inches back from the leading edge my CG is, but with the hatck off, it balances from the wing tube.. The extra long tail moment and the oversized horizontal stab allow the plane to fly with the cg back.. Mine tracks straight and true, with very little down elevator input for inverted flight.. It is a perfect IMAC plane!! It also 3Ds very well! very solid harriers, and easy torque rolls! The only thing it won't do is Wall.. It just flies on through.. Mine weighs 14 lbs.. a little haevy, but that's the Moki!!! It may be on the heavy side, but it flies so good, you would think it weighed 10 lbs!! It doesn't act like it's oerweight!
I'm certain that your plane weighs less than mine, even with a little lead up front! Don't pass this plane up!! It's not a pig!!
Here are some pics
http://www.rcuniverse.com/forum/upfi...70/Ig12852.jpg
http://www.rcuniverse.com/forum/upfi...70/Ki18810.jpg
http://www.rcuniverse.com/forum/upfi...70/Cx74544.jpg
