RCU Forums - View Single Post - Balsa USA Stick Forty Plus
Old 05-15-2004 | 07:50 PM
  #42
longboard
Default RE: Balsa USA Stick Forty Plus
I'm building a Stick 40 Plus right now.I've got the fuselage and half the wing done.The outer nyrod sheaths for the aileron pushrods go between the spars at the 3rd and 5th rib bay do I need to run the shear webs out that far if i also glass the center section?I'm going to use some glass gloth I got at a marine supply store that I used to do some body work on my car,not sure of the weight but it's not very thick.willit do the trick or should I use glass cloth designed(?) for models?
