7CAP Setup
I am trying to set up my 7CAP. I have 2 aileron servos and 2 flap servos (single rudder and elevator, of course throttle). Each aileron and flap servo is plugged into it's own receiver channel. Ailerons in Ch 1 & 7, Flaps in 5 & 6.
With standard factory settings I had no aileron servo movement in response to stick input. When I turned the flap knob only the left flap moved. Left aileron and right flap moved when I activated swithch 5 & 6. No right aileron.
Then I tried to get into the mixing. First I went to the Parameter menu and set Ch 5 & 6 switches to null. Next I tried mixing ch 1/7 (under PMIX 2 with no Rate or Offsett) and Ch 5/6 (under PMIX 1 with no Rate or Offsett).
Long story short, this did nothing. I still only had a single left flap and no ailerons. Any help is appreciated. Thanks
