i have a hot bodies lightning 2 rr. all was well. i had the buggy up to 48mph with some to play with aswell.
i started up the next session went well for a while until i rolled it. the engine after that peaked at 28 mph. this remained so until i turned the needle past the recommeded warning point. in this case 2 1/2 turns from closed. Once at this level the car was like a rato rocket, but i dont want to keep this setting incase the engine overheats etc. the minute i turn it under i mean even 1mm the engine slows. i have brocken the car in correctly, adjusting between refuels and only at specified increments.
Any suggestions why, or ways to return it to normal?
Should i restore factory settings and start again, is this ok or will damage it?
Please reply
