RCU Forums - View Single Post - .26 for lightning 2 rr help???
Old 05-17-2004 | 03:04 PM
FireStorm-GA-
Default RE: .26 for lightning 2 rr help???
Hi there M8
I had to rest to Factory settings when my glow plug whent bad and I didnt relise and I had adjusted my settings instead DOH. The only thing I would say is whach out for the mid range needle as whent you rest the LSN it will turn the mid range needle out and mess every thing up (yes thast happened to me and took me nearly a week to get it running nicely again). Just use 2 screw dirvies 1 in mid range to make sure it dose not move while you turn the LSN back in.
Mine is now running very nice well except for the steering arm braking when the caphead screw at the bottom came out DOH. I have found that nearly all the screws have pleanty of locktite on them but you must check them all as 1 or 2 dont have any doh.
