RE: Desire 60 build, first jig built balsa.
Gee Tom,
I have to believe your press is lighter than the 2 pieces of pool table slate that I use for sheeting wings - about 90 lbs each. One on the bottom and one on top. Then I add more weight on top (about another 100lbs for wings.
How long does it take for the urethane glue to cure? I usually allow at least 24 hours of cure time using epoxy.
The Desire looks good so far!!
-Will B.
