RE: 7CAP Throttle Cutoff
Hi max42,
If you set up both using the same switch, when you flip the switch for your dual rates, your throttle will of course cut down. It is definitely recommended to reset your switches if you plan on using both Throttle cut and your Elevator dual rates.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
