RE: Which plug?
They are both the same, both made by OS. The only difference is the name.
Plug life is determined by the how you operate the engine. I have seen them go 50 flights, and others can only make them last 5 flights. If you are having trouble with short plug life, you are likely running the engine too lean or with too much prop.
