YS Engines Support Direct support from YS Performance Engines by Dave Shadel
Which plug?
Old 05-19-2004 | 08:58 AM
Default Which plug?
What are the benefits of the YS plug over an OS F?
How long should I expect a plug to last, in terms of gallons of fuel (assuming best practice operation in terms of fuel/oil, average air temperature/11x7 prop etc...)
Old 05-19-2004 | 01:22 PM
Default RE: Which plug?
They are both the same, both made by OS. The only difference is the name.
Plug life is determined by the how you operate the engine. I have seen them go 50 flights, and others can only make them last 5 flights. If you are having trouble with short plug life, you are likely running the engine too lean or with too much prop.
Old 05-20-2004 | 07:44 AM
Cool, I must be doing something right - I can't remember the last time I changed a plug!
The normal precursor to plug change seems to be poor idle & pick-up, would you concur?
thanks
Julian
Old 05-20-2004 | 10:21 AM
agreed
