RCU Forums - View Single Post - Outrigger construction question
Old 05-21-2004 | 09:48 AM
Mr Cajun Gator
Default RE: Outrigger construction question
epoxy blocks of hardwood inside the main hull then drill every thing, hull,(block and boom tube) then bolt up. It is ok if you screw through the hull, but if you use a blind "T" nut inserted in the hardwood before attaching it to the main hull, is a better way.
