RE: setting pitch
thank you for your advice. i will go through all of my links again to make sure that they are set up correctly. i agree with the excessive + pitch. i thought that was a bit much. the problem i am also running into is, the JR6102 only has two flight modes (normal, and stunt). so i guess i will have to setup my hover/normal flight in normal mode, and my more adventureous settings in the stunt mode. will this work? thanks again for all of the help.
jason
