RE: You can do 3D Help
If you put the tank in the front at the right height it will be OK. The easiest setup to use and get to work right is with either a Cline or Iron Bay regulator.
The regulator has the additional advantage that it allows you to put the tank over the CG so no changes as you consume fuel.
