You can do 3D Help
FL
i have an OS 91 FX and am putting it in the U can do its mounted inverted will i have any problems with running it inverted like flooding the card if i do what kind of pump should i use and how much is it. thx
If you put the tank in the front at the right height it will be OK. The easiest setup to use and get to work right is with either a Cline or Iron Bay regulator.
The regulator has the additional advantage that it allows you to put the tank over the CG so no changes as you consume fuel.
