RE: GP RV-4
I noticed you have your servos mounted very far forward. You might be sorry. I used a .46FX and I ended up needing to mount the battery in the extreme rear of the plane (extreme as in under the stab) to get the plane to balance. Make sure you check your CG prior to covering!
