RCU Forums - View Single Post - glitching problem with Rx or tx,how to verify the problem
Old 07-04-2002 | 10:56 AM
petergomes
Default glitching problem with Rx or tx,how to verify the problem
Dear all,
Im really very surpised that My futaba 6va is not responding to my RX or vice versa & my observation was after charging both Rx & Tx for 15 hours I then connect my Rx batt to Rx & check all servoes function,for the first Five minutes the RX & TX both respond percfectly fine then the next four to five minutes,all servoes start glitching.
The Tx reading on volt meter shows 80 to 90 % but keeps varing from 60 to 80%.,also checked all connectors which are slightly green in colours,must be the contact is bad,therefore cleant the connectors(green)but the glicthing problem still pursist.
Previously I had a dought on the Rx batt,since there is no way of checking the volt left in the Rx batt,therefore bought a new Rx Dry batt & installed new Duracell(Alkaline).
I again tried above test with the Tx & Rx dry batt installed in the model but observed the same as above after 5 minutes,the same glitching occurs.
Yesterday,I again both new Duracell dry batt for Rx & tried the same excercise but this time there was no response from either Tx or Rx from the begining meaning nothing responded,(no Tx/NO Rx but only glitching while the Tx was close to 6 inches from Rx antenna.other wise total dead.
Once while cleaning the contacts,I had removed the crystal & that fell from my hands to the ground,could it be possible that the crystal is damaged & not working?Could that he the culprit & control tranmission??????
what is the function of crystal.
pls help me.
Presently I sent my Tx & Rx to My dearest friend Nilesh Doshi-Grest guy & aeromodeller & also a full fledged commericial pilot,to check both set.
pls help me urgently
thanks & regards
peter
