Go to ebay and look for real157 he sells 3s li-polys and 3s2p they are very reliable he can even make a custom pack it does cost more but hey can make them just about anyway you want. here are some links for his batts.
1600mah 3s 2p
http://cgi.ebay.com/ws/eBayISAPI.dll
ViewItem&category=2563&item=5900650011&rd=1&ssPage Name=WDVW
800 mah 3s1p
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=5900650938
Also you can go to
www.foamyfactory.com and look at there planes My favorite is the ultimate. you print plans and make templates and then build you plane tim will give you all the help you
need.
P.S. if those don't work try this
http://cgi6.ebay.com/ws/eBayISAPI.dl...sort=3&rows=50
As far as the reciver go with a berg it will save your airplanes it's 50.00 usd @
www.allerc.com
for servos get the gws pico those are my favorite cheap light and lots of torque for weight. you can get those at
www.allerc.com
if you don't have an engine don't skimp here go with a mega 16/7/10 ask real15 he also makes custom gearboxes for them don't buy the mega or mec gearboxes go with his gearboxes the best I have ever used. I run his 3 to one on a 13x6.5 prop and it gets 32 oz of thrust at 9 amps.
But be sure to get a hold of real157 on ebay he will hook you up he did me his service is also great.
