RCU Forums - View Single Post - YS .63 will it run on 15%?
Old 05-27-2004 | 12:06 PM
Funtana_Cody
Banned
Default RE: YS .63 will it run on 15%?
ORIGINAL: billben55
I don't have the flip yet but should be less than 5 lbs. For some reason the local hobby shops carry 10, 15 or 30% nitro but not 20%. I'm too cheap to buy the 30% heli fuel. I may be able to special order the 20% though.
As far as the lube, Wildcat has 18% oil and Bryons has 16% - I've added Byrons castor oil to bring the % to 20 for my Saito .72. Some at the field I go to use regular glow fuel (10 or 15% nitro and 16% oil mixture) on Saito's w/o any problems.
Have you run the YS on 15% w/o starting or other problems? Thanks for the feedback
Bill
NOOOO NOOOO NOOOO[X(][X(] Do NOT use castor oil on the 4 -bangers!!!!!!!!!Castor oil tends to build up around the valves!!!!!!!! Use ONLY synthetic oil!
