RE: FuntanaS 40 is FUN
sry for my critisisum of JR but if you try that mix with a little exponential say 30% it can make the manuver much smoother but put it in so it only engages when you pull up elevator it is not good for down cause it some times stalls recovery time and for spacy move it back an 1/2 inch and try that if you feel no difference move it back 1/4 more you should start to see some results. with is back you will notice when you pull into a wall with that mix you will slide forward while vertical cool but rearward CG helpd keep the plane balaced when vertical from my expariments.
