RCU Forums - View Single Post - Inverting motor mount on 46 UCD
Old 05-29-2004 | 12:14 AM
fiveoboy01's Avatar
fiveoboy01
Default RE: Inverting motor mount on 46 UCD
Just a heads-up on mounting it upright-
This will throw off the thrust lines.
If you still want to use the cowl, you won't be able to. Flipping the motor mount around will raise the engine and the crankshaft/spinner plate won't line up with the hole in the cowl.
