RCU Forums - View Single Post - I need help!!!!!
Old 05-29-2004 | 09:23 PM
Beowoulf
Default RE: I need help!!!!!
You should probably forget about the body until you learn to fly really well ... either that or buy some stock in Smartech...
The main drive gear? Try here... http://www.raidentech.com/19tagebig.html
While you are ordering... you should probably get some other parts also: Main rotor blades, for sure ... tail rotor, probably ... tail motor, so I have heard ... landing gear and the 4 struts that stick into it....
Ideally.... You could have a replacement part on hand for EVERYTHING! [:-]
