I need help!!!!!
WA
I just got an AreoHawk on 5/27/04. I had an accident while in flight. I need to get a new outer body and a main drive gear. Does anyone know of a web site to smartech or any other a web site where I can get a body kit for it if so please let me know so I can get going again.
william1tyu
william1tyu
You should probably forget about the body until you learn to fly really well ... either that or buy some stock in Smartech...
The main drive gear? Try here... http://www.raidentech.com/19tagebig.html
While you are ordering... you should probably get some other parts also: Main rotor blades, for sure ... tail rotor, probably ... tail motor, so I have heard ... landing gear and the 4 struts that stick into it....
Ideally.... You could have a replacement part on hand for EVERYTHING! [:-]
