BASIN BUM, How do you like those Du-Bro 4-40 kwick links with the locking tab. I'm using them for the first time. If the lock gets "bumped" open then the brass pin might vibrate out!?!? Have you used them for a while with out any problems? They do fit nicely into the holes on the control horns.
mustangflyboy, 1/4 oz weight on the the wing tip is nothing to lose sleep over, but if you do wish to install it, locate the weight on the side of the wing tip at the CG.
Gunny
