RE: Quick Help on Funtana
Well I have just got things ready in the car for today, weather is glorious, not a cloud in sight and bright sunshine plus no trees are blowing and it's only 8.45am. Could be a nice day. S Raptor 30, Funtana and Wot 4 in the car ready for the off.
I got the Funtana to balance nicely at around 5.25 - 5.5 inches from LE, throttle servo at moment is in stock position. Had to put some lead in at the front in foam under fuel tank including the battery to balance out. Will see how it goes. Done movements as recommended for initial test fly plus dialed in dual rates for 3D when the time comes along with a little Expo to soften things a little round neutral.
I shall let you know how it all goes, this will be the first time the engine has even started so will run a tank through it first anyhow using 16%
